I recently got an lg 34um67 mainly fort the 75hz and freesync as I have a fury x I was wondering the first time I enabled freesync in the monitors settings catalyst prompted me to check some box to enable it after which I had to reset all settings in catalyst due to other issues and now it doesent prompt be I dont know how to enable it games have screen tearing while fps is in freesync range 48-75 note I am running 15.8.1 beta drivers
Edit: There is nothing under properties in display settings
https://linustechtips.com/topic/453887-how-to-enable-freesync/
hold up,hold up, slow down, wait, what?
freesink doesnt prompt up to be enabled after an issue?
got freesink,
got gpu,
what cataltst, which games
https://linustechtips.com/topic/453887-how-to-enable-freesync/#findComment-6088291
got freesink,
got gpu,
sink = a basin or receptacle, as in a kitchen or laundry, usually connected with a water supply and drainage system, for washing dishes, clothing, etc.
sync= synchronization: harmony or harmonious relationship
https://linustechtips.com/topic/453887-how-to-enable-freesync/#findComment-6088398
No such thing as dp 1.3 and yes im useing the dp 1.2 plug if I was not I would not be able to enable freesync in the monitor settings
My bad. 1.2. The monitor might have multiple DP outputs, and only one being 1.2.
However, I am starting to think that you should contact LG support directly.
https://linustechtips.com/topic/453887-how-to-enable-freesync/#findComment-6088757
