Help me plan a custom loop :D
Solved by Interfectorem,
Here's what I compiled, sorry that it's slightly over budget at $412. I also recommend purchasing from PerformancePCs.com
CPU Block- EK-Supremacy EVO - Nickel/Plexi (Clear as you requested) $116.89 (Incl. 6 Fittings in Combo Deal)
Radiator- EK-Coolstream XE 360 (Triple fan and outstanding performance) $99.99
Reservoir & Pump- XSPC D5 Photon 170 $149.95
Fluid- 1L of Mayhem's Pastel Blue Berry $19.95
Tubing- 3m of PrimoFLEX AdvancedLRT (3/8 ID & 5/8 OU) Clear $24.99
Fittings- 6x EK-ACF 10/16mm (3/8 x 5/8) Black fittings (Incl. w/ CPU block combo deal)
