I just started my bow build and I am replacing the two front 140mm fans on the 780T with three 120mm fans but I can not find which holes yo mount them in. Please help!!
Corsair Graphite 780T | Intel 6700k @ 4.7GHz | Maximus VIII Hero | Corsair Vengeance LPX @ 3000MHz | Asus Strix 980 Ti| Mushkin        Enhanced Chronos 256GB | Samsung 850 Evo 500GB | Seagate Barracuda 1TB + 3TB
https://linustechtips.com/topic/452570-corsair-780t-help/
Well I know for a fact that its possible, because when mine arrives next week I am doing the same thing and I have seen it done many times
Have a look at the MB Manual
https://linustechtips.com/topic/452570-corsair-780t-help/#findComment-6069400
Okay I found out that I have to mount them on the inside, but there are no bolts to secure them in place.
https://linustechtips.com/topic/452570-corsair-780t-help/#findComment-6069413
Seeing this picture though, I see it is possible, but the fans don't appear to be screwed in. Possibly having the fans on the other side screwed in would do the trick.
500x1000px-LL-be77f1fd_20140907_001221.j
https://linustechtips.com/topic/452570-corsair-780t-help/#findComment-6069426
Well I got them all on but without bolting them in as the second picture shows. It has to be said, this is a bit of an oversight by Corsair. With the front mesh on however it seems to hold them in place well enough. Thanks for all the tips.
https://linustechtips.com/topic/452570-corsair-780t-help/#findComment-6069478
The screws should come with the fans - check the packaging they came in.
To attach them you need to remove the three HDD cages ( three SSD mounts latch to the rear of the motherboard tray - it's easiest to remove these to build in, but less work if you can work around them ) and screw them into the chassis from the inside. This is because of the mesh that goes over the front panel - it doesn't bear weight. It also allows radiators to be directly attached to the frame since it can bear more weight.
https://linustechtips.com/topic/452570-corsair-780t-help/#findComment-6069481
