So i want to buy the r9 290 from diamond. The model number is r9290d54g. The problem is that it says in the spec sheet it has a 384bit bus. That doesnt sound right because the reference R9 290 has a 512 bit bus. Is this a mistake or a scam?
Here is the product page: http://www.diamondmm.com/r9290d54g-diamond-amd-r9290-memory-graphics-video-card.html
https://linustechtips.com/topic/451279-reference-diamond-r9-290/
