Anyone have experience getting an Xbox 360 controller to work on a PC? I have the adaptor, but the controller doesn't seem to connect.
I have the driver, I have the controller (new batteries and all), and I have the options in games set for controller. I pressed the connect buttons (and it connected properly) Any ideas?
NOTE: The green ring DOES flash the entire time; could that be it?
GIGABYTE Z97MX-G516GB DDR3 | I5 4690k @ 4.4ghz | 1TB SSHD, 500GB HDD, 128GB SSD | GTX 1070 8GB | Corsair Graphite 230 | EVGA 650W | Hyper 212 EVO
Cinebench R15: 636(all cores), 127FPS
https://linustechtips.com/topic/451003-xbox-controller-on-pc-not-working/
Do you have a wireless receiver or a Plug and Play adapter? (the wire)
The green ring flashing all the time means that it can't find hardware to connect to. I had the same issue and resulted in buying a wireless receiver. You can get them for I think around 20 bucks. This worked for me anyway. Hope this helps you out :)
I did it in windows 7, now run windows 10
Edited by RedPizzaHead
If you're in Windows 10 read this,
Is this a wireless controller? If so go to device manager>Xbox 360 Peripherals>Xbox 360 Wireless Receiver For Windows>Update Driver Software>Browse my computer for driver software>Let me pick from a list of device drivers on my computer>There should be two versions for Xbox 360 Wireless Receiver, Try the top one, if it doesn't work repeat the steps and try the bottom one
CPU: Intel Core i7-4790K | GPU: GTX 1080Ti | Case: Corsair 750D Airflow | Motherboard: ASUS Maximus Formula VI | RAM: 16GB Vengeance Pro | PSU: Corsair AX860
SSD/HDD(s): SAMSUNG 850 EVO 120GB, SAMSUNG PM830 256GB, SEAGATE 6TB | Optical Drive: Sony Optiarc AD-5280S CB-PLUS
you need a wireless reciever so your PC can use the bluetooth option with your wireless controller.....something like this..... http://www.newegg.com/Product/Product.aspx?Item=9SIA1KT2J01458&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-Wireless+Accessories-_-9SIA1KT2J01458&gclid=CjwKEAjwpuSvBRDSkaes4OasuEESJACfwIc_jP-Akl365AisV8xarzqlG20KHBm8aUbQFElQkvzCxxoCDgHw_wcB&gclsrc=aw.ds
plug n play will not work.....xbox 360 controllers do not have bluetooth....therefore you need the wireless reciever to read your controller
MSI X99 SLI KRAIT EDITION- i7 5820k - EVGA GTX 960 4GB SSC - 600W PSU - 16GB RAM - 480 GB SSD/2 TB HDD - WINDOWS 8.1 PRO
Wireless receiver.
for me it's just plug and play. I have win 10 if that matters. for the record I hope it stays busted because that color font is jacked!  :P  :P
Don't know what you are talking about by color font. It's fine for me?
Xbox 360 peripherals doesn't show up.
As it should be mentioned above, I have the receiver...
Probably didnt install the driver correctly and since it a built in driver its kinda a pain to correct as yo uhave to select th correct one from a list.
Just found it in the device manager as "uninstalled driver"
Any idea on how to fix?
Doing the one from the MS website says "driver already installed"
"1) Install Microsoft's 360 controller software. If you Google "microsoft 360 drivers" it will be the second hit from the top.
2) With receiver plugged in, go to Device Manager > Other Devices.
3) You should see an Unknown Device. Uninstall its drivers.
4) Unplug receiver, then plug it back in.
5) You should see the same Unknown Device reappear under Other Devices.
6) Update Drivers for Other Device.
7) Select "Browse my computer for device software" then "Let me pick from a list of device drivers on my computer"
8) Choose Microsoft as the manufacturer, then look towards the bottom of the list for "Xbox 360 Wireless Receiver for Windows" and install the software.
9) At this point (hopefully) you should be able to sync the devices together."
I have xbox 360 peripherals and xbox peripherals in the list. nothing under xbox 360 wireless receiver for windows.
Which do I choose?
Try 360 first as the other I believe is for xbo.
Ok which version? 2007, 2015, 2009? I'm assuming wireless.
Wireless yes, and I think 2015 would be the most updated if you mean the driver.
Receiver or wireless? I'm going to try receiver.
Fixed! Thank you!
this is great except i cant read it...
1) Install Microsoft's 360 controller software.  If you Google "Microsoft 360 drivers" it will be the second from the top.
7) Select "Brose my computer for device software" then "Let me pick from a list of device drivers on my computer"
9) At this point, you should be able to sync the devices together.
Perfect!
I wrote it out this time instead of doing a copy pasta.
Just use code view? Formatting doesnt get pasted in and its far easier to remove it.
When I'm not lazy I'll do that.  xD
its actually quicker...
I meant it was faster to just copy and paste.
yes and if you would have pasted in code view on the forum it wouldnt have transferred any formatting ;)
Maybe I'm just plotting against those using night theme?
better question is why arnt you using the night theme?
