i mean like
if you want to use the onboard graphics, you plug your monitor to the motherboard
if you want to use your dedicated graphics, you plug it to the videocard.
the system will automatically switch to the dedicated. no need to disable it. oorrr you can jsut disable it, it probably won't change anything tho
There is no such thing as a bad PC, there are only BETTER PCs
https://linustechtips.com/topic/450965-onboard-chip-settings/#findComment-6046790
