Using different fans with H110
Go to solution Solved by Whorax,
Those are airflow fans, not meant for radiators. You'll want pressure optimized fans that are actually meant to push air through a radiator.
Hey LTT forums, quick question here. Would these fans work well to replace the ones that came with my H110?
 http://www.amazon.ca/Corsair-AF120-Quiet-Airflow-CO-9050016-RLED/dp/B00F6S0XJO/ref=sr_1_7?s=electronics&ie=UTF8&qid=1442364101&sr=1-7&keywords=case+fan
CPU: i7 5820K @ 4.00GHz Mobo: ASUS X99-DELUXE LGA 2011-v3RAM: Corsair LPX 64GB Quad-Channel DDR4 @ 2400MHzGPU: GTX 970 x2 SLI | Storage: 250 GB AMD SSD x 4 Raid 0
https://linustechtips.com/topic/450682-using-different-fans-with-h110/
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
PCPartPicker link: http://pcpartpicker.com/p/R6GTGX
Привет товарищ ))))
corsair is a funky company...using other thermal paste or what we typically say are better fans dont really increase anything in a better way and in a lot of cases make it a little worse. They make those AIO's pretty damn tight to corsair specs that just all work very well together.
