I decided to overclock my GPU today.  I have an  MSI GTX 970.  The card passed the OCCT stress tests and ran perfectly fine until I decided to run a 3Dmark test on it to see how much it improved.  The score ended up being nearly 3000 points lower than my scores at a stock speed.  What did I do wrong?
Stock Speed - http://www.3dmark.com/3dm/8565305
Overclock Speed - http://www.3dmark.com/3dm/8565320
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/449621-gpu-overclocking-help/
was the card turboing up all the way? any thermal limits?
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/449621-gpu-overclocking-help/#findComment-6028191
Nope.  It was stuck at 540mhz.  Temps were also pretty low.
https://linustechtips.com/topic/449621-gpu-overclocking-help/#findComment-6028216
When my core clocks get stuck at low MHz, it means my drivers crashed and recovered. Usually, adjusting the core clock will fix it. If not, reset and try for a lower overclock. It's probably not stable.
| Corsair Carbide Series 350D |Corsair H100i | Intel i7 5820k @ 4.5GHz, 1.175v | EVGA x99 Micro 2 | G.Skill Trident Z 32gb, 3200MHz
| Gigabyte G1 Gaming 980Ti @1506MHz | EVGA P2 850 Watt | 2x Samsung 850 Evo 500gb | Western Digital Red Pro 6TB |
https://linustechtips.com/topic/449621-gpu-overclocking-help/#findComment-6028307
  • 2 months later...
When in a benchmark the dirvers crash and recover, they lock up at 540mhz, try rebooting your system and it should be fine
No.  That wasn't the problem.  The stress test I used (OCCT) only works when the stress test window is in the foreground.  When I was stress testing, I was doing other things at the same time.  Somehow, I thought that it was stable and I let it be.  My bad.
https://linustechtips.com/topic/449621-gpu-overclocking-help/#findComment-6629756
