I have an old GTX 650 and a friend of mine wants to buy it but the heatsink/fan is pretty messed up there is a blade missing on the fan and the heatsink has a crack in, I have no idea how this has happened.
So I need to find an aftermarket GPU cooler but I haven't dealt with this kind of thing before apart from watercooling the card and in this case its not worth it. So if any one here knows a decent cooling solution that's pretty low cost could you throw some suggestions my way?
U.K currency and stores only though please
Cheers Guys.
Nothing Is True, Everything Is Permitted
(Do not try to work the meaning out you will go insane I have tried it)
https://linustechtips.com/topic/44838-aftermarket-gpu-cooler/
Ask him if he threw the gpu while he had it. Anyways a simple trip to ebay should be fine as there are a bunch of broken cards that have working coolers. Or just get that arctic cooler one.
Listen if you care.
https://linustechtips.com/topic/44838-aftermarket-gpu-cooler/#findComment-588924
