High bandwidth over long range
So guys im in need of your assistance.
I need a way to get a 2km of range and as much bandwidth as possible, the catch is that its a UAV that is going to be broadcasting a video signal so space is an issue.
I am perfectly fine with a one way signal (UAV -> station), i can also track the UAV with the receiver antenna. So i was thinking of experimenting with those cheap antennas on ebay, but what could i use for the UAV in terms of transmission ? Or maybe there is some other way to do this ?
Something wrong with your connection ?
Run the damn cable :)
https://linustechtips.com/topic/44835-high-bandwidth-over-long-range/
well there s directional wifi antennas but you would need line of sight and a way to follow the uav with antennas on both sides.
what about strapping your phone on the uav sharong his 3g/4g?
Anything I write is just a comment, take is as such, there is no guarantees associated with anything I say.
ATX Portable rig (smaller than prodigy(LOL)) :  Nmedia 2800 | Gigabyte Z77x-ud3h  | Corsair HX1000 | Scythe Big Shuriken | i5 3570K  |  XFX R9 290 DoubleD | Corsair Vengeance 32GB
