but if i put a splitter is unless buy a 3.0 frontal panel because read 2.0
Is it really worth it to swap out your mobo just so that your frontpanel runs 3.0? i wouldn't bother imo. Especially if there is 3.0 on the rear i/o
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/447944-i-need-a-mobo-help/#findComment-6006152
so i can't istall usb 3.0
Before I spent any money I would make sure that your CPU supports USB 3.0 and if it does then I would get one of these http://www.newegg.com/Product/Product.aspx?Item=9SIA4UB39Y0333&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-Controllers+%2f+RAID+Cards-_-9SIA4UB39Y0333&gclid=Cj0KEQjw98mvBRD-_ciSovKhq7gBEiQAEvsBZ0eNWyNV4Fg_Tt-mvGXbMmhXWMv55AxgaEIswxbBGrEaAo1p8P8HAQ&gclsrc=aw.ds if your motherboard does not have the usb 3.0 header on the motherboard
https://linustechtips.com/topic/447944-i-need-a-mobo-help/#findComment-6006464
