hi. as usual i got issues with my rig when ever i try to do something new.
i tried to oc my system even further cause why not? and i end up screwing the h100i cpu fan connector.
now i have the stock fans that come with h100i connected to the motherboard pwn connectors.
how can i increase their speed? in the corsair link software i see them connected but i cant increase their speed and in the asus AI suite, well thats the most shittiest software i have ever seen in my entire life at least for tweaking system.
any other software where i can change speed of these stock corsair fans? because currently these are running on my old setting profile in the link and htats why they are running at around 1100 rpm but i know these can go upto 2500rpm so just need to know if there is any software which allows me to increase or decrease speed of these fans?
thanks in advance
Current Rig: Intel core i7 4770K Stock 4.5G, Asus Maximus VI Hero, Corsair Vengeance 1600Mhz 16Gb (8Gx2), 2x SLi Gigabyte Geforce GTX 670 2Gb GDDR5 3X Windforce Edition, Corsair Hydro Series H100i (Push), JDS LABS O2/ODAC combo, Fiio E18 KUNLUN, Asus Xonar Essence STX (secondary PC), Sennheiser HD700, Hifiman HE 400i, Beyerdynamics DT 990 PRO 250 Ohm, Sennheiser HD 518, Cooler Master Silent Pro M2 850W 80+, Cooler Master CM 690 II Advanced, Samsun4g DVD R/W Combo, 3X Cooler Master 120mm Blue LED fans, LG IPS 23EA73, Logitech G710 BLUE, BlackWidow Ultimate 2013 Edition,Logitech G402 HYPERION FURY, Bloody Core V7, SteelSeries QcK Mass MiBR mouse pad
https://linustechtips.com/topic/447920-fan-speeds-controlling/
can no body here help me? now im getting this problem where my fans that are actually attached to the radiator of the H100i are connected to the motherboard pwm connectors and now they increase or decrease speed on their own. they become very loud when cpu load is increased, even if im opening new chrome tab because cpu usage is increased just a little.
its annoying. pls anyone help me and tell which software or way to use to set the speed of fans on my own. i have used the Corsair link and it does not work at all. it just shows me the maximum speed of the fans in information section and thats is it. nothing is there to change the speed of these fans.
HALP pls :(
https://linustechtips.com/topic/447920-fan-speeds-controlling/#findComment-6012702
-SNIP-
The pump is set at one speed but for the fans if you connect them to your motherboard you can control them easily from there with an Asus board either through the BIOS or AI Suite. Make sure you have the settings in the BIOS as either DC voltage control for 3 pin fans and PWM for 4 pin fans or you won't be able to control it.
https://linustechtips.com/topic/447920-fan-speeds-controlling/#findComment-6016560
Everything this man said, hope you can adjust the curve however as my board controls the fans all shitty and I just use a fan controller.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/447920-fan-speeds-controlling/#findComment-6017107
