Looking for help with Dxtory.
Solved by ohitsluca,
you should really try out obs
Dxtory is superior, because of the separate audio tracks when editing.
OP, check out JackFrags tutorial on YouTube. He walks you through it all.
Forvirrad ·
Posted in New Builds and Planning1 -
MiszS ·
Posted in Troubleshooting4 -
1
1
1
Liberty610 ·
Posted in CPUs, Motherboards, and Memory4 -
1
ronaldowrld ·
Posted in Troubleshooting2 -
GC180 ·
Posted in Troubleshooting5
play_circle_filled
Latest From Linus Tech Tips:
AMD Is Copying The Worst Thing About Intel - WAN Show May 31, 2024
