I have a floor lamp next to my desk, with a foot switch, that is plugged in to the same power board as my PC.
Sometimes when I turn it OFF, I will hear the USB disconnect sound and I've only just noticed that it's my Xbox One controller that is disconnecting, forcing me to unplug and replug it back it.
Is it possible this is because my lamp is sending some power surge into the board? Will this explode my PC into a million pieces? Because that would be very unfortunate and costly and messy and OH PLEASE GOD I DON'T WANT TO EXPLODE
PC: i7-3770k, GTX 670, 16gb 1600mhz, SSDs only, Corsair K70, Razer Deathadder, Windows 10.
Xbone
https://linustechtips.com/topic/445561-possible-power-surge/
Happens with my fan. When I turn it off my light goes out or turns non. Not sure exactly...
Cheap power bar?
I certainly wouldn't say it's the best ever...
Probably a good time to invest in something a little better
Xbone
https://linustechtips.com/topic/445561-possible-power-surge/#findComment-5971196
Anything's possible but if your PSU is at least somewhat high quality, it'll have protection. You can also get an external surge protector for it.
My PSU should be alright, OCZ 750w.
My power board does have surge protection, but it's probably not the best
Yeah mine is cheap so I'm assuming that's why this happens. Bad ground?
I honestly have NO IDEA how to ground ANYTHING and have no understanding of it whatsoever.
All those times they say to ground yourself before touching electronics? No idea. Ignore. Blow stuff up. Whatever.
Xbone
https://linustechtips.com/topic/445561-possible-power-surge/#findComment-5971220
Touch anything metal to ground yourself haha. I meant bad ground as in the power bar may have a bad ground connection.
blackshades on
https://linustechtips.com/topic/445561-possible-power-surge/#findComment-5971229
The metal object has to be a certain size or attached to anything? Does touching a freaking screwdriver do that?
I assume its ground connection is fine. And from what I can tell, the only plug in my power board that doesn't have a ground connection is an External HDD (third, bottom, prong is ground. This I know).
Edit: Scrap that, of course the HDD has ground. DUH
Xbone
https://linustechtips.com/topic/445561-possible-power-surge/#findComment-5971263
Touch something larger. Door knobs work well.
blackshades on
https://linustechtips.com/topic/445561-possible-power-surge/#findComment-5971267
