ASUS x99 PRO --ISSUES--
Hey guys-
Thanks for the help with the boot problem I had last year.
New issues have arose.
-Booting will result in one of the following:
1. Code 61 - NVRAM init. - doesnt progress further in Boot Sequence.
2. Overclocking Failed! Screen 'press f1 to enter BIOS'
3. Attempt to go into Automatic Repair (50% of the time it will continue, the other half it will lock up)
4. If it DOES boot..... here's a video of what happens.
Okay so this is actually a problem with the UEFI. You're going to want to do a couple of things.
First clear your CMOS.
Second, back up ALL of your data.
Third, update your UEFI to the latest version (even if you already have it, just go ahead and force it to update again)
Fourth, restore the UEFI to default settings and LEAVE IT THERE!
Fifth, Make sure your RAM is right.
Sixth, do a clean install of Windows.
