Help me pl0x
  My dad has a pretty old PC with winXP, so I decided to swap the OS HDD for a SSD with win7 pre-installed, but when I booted with the new SSD, it asked me to choose whether to boot safe mode, last known boot, or normal boot, and when I choose normal boot It just shows the windows logo and it reboots itself, going back to the options again, same with the Last known boot option (this time the logo stays longer, then it reboots again).
  Is it the compatibility issue? or am I doing something wrong?
  here's the build of the old pc
Intel Pentium E5400
P5KPL-AM-CKD-VISUM-SI mobo
DDR2 2 GB PC2-5300
Thanks in advance!
https://linustechtips.com/topic/443265-swap-drive-help/
you should reinstall windows while the new drive is in the system
any not all xp systems support 7, just keep that in the back of your head
so Ill have to install windows 7 again on top of the SSD with pre-installed win7 for it to work?
will I need the cd key again? or can I just get a USB with OS?
https://linustechtips.com/topic/443265-swap-drive-help/#findComment-5940895
