Radiator Questions
Go to solution Solved by SonoDanshi,
If you have room for a 360mm or 420mm rad in your system then go for that over a single 240/280mm one.
You also need to buy 2 compression fittings per item in your loop but you have 4 components (CPU block, GPU block, pump/res combo and the radiator) so you'll need to order 8 fittings and not 6.
One last point - I see you have links to frozencpu. Whilst they are now back in business, after what happened I still wouldn't trust them with my money and would rather suggest performance-pcs as the safe option.
I am creating this build that I plan to buy: pcpartpicker.com/p/YG7dVn . What do you recommend I get: a two-fan radiator or a three-fan radiator. I'm kind of a noob at watercooling so any feedback would help.
Thanks
HenryI would get a three fan radiator
https://linustechtips.com/topic/442654-radiator-questions/#findComment-5932829
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
https://linustechtips.com/topic/442654-radiator-questions/#findComment-5932881
I have updated my thing to this: http://pcpartpicker.com/p/7YPcnQ . Thank you for your feedback, very much.
OK one last thing. The tubing and the compression fittings are incompatible. If you want to stick with the orange tubing in your link then you will need the following compression fittings:
XSPC Coin Fit V2 - G1/4 to 7/16 ID 5/8 OD Compression Fitting - Black Chrome
aaaaaaaaand I just noticed yet another thing. You've selected a multi port radiator that contains 6 potential ports for the water to move through. As you'll only be connecting 2 of those ports you'll need to plug the remaining 4 holes.
So grab 4 of these or something similar to this
https://linustechtips.com/topic/442654-radiator-questions/#findComment-5933444
The rad will come with plugs installed so the OP will not need plugs...
I'd suggest that the OP gets a better motherboard though to match that power hungry CPU...
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/442654-radiator-questions/#findComment-5935031
No it won't.
Please note: This product does not include G1/4" blanks, they can be purchased seperatley [sic]
https://linustechtips.com/topic/442654-radiator-questions/#findComment-5935277
No it won't.
$80+ and no blanks? Wow I'm actually shocked, my alphacool came with blanks and so did my 360, what a waste of money...
Chernobyl
Kraken
https://linustechtips.com/topic/442654-radiator-questions/#findComment-5935603
