Hello All,
I was given a HP Laptop that has an AMD A8 6410/radeon r 5 graphics, with 4gb of Ram.  This little laptop works great for my REALTOR work.  However, when I'm not working I like to play games.  I've run into some trouble here with newer games not wanting to work.  I'm assuming my problem is having an APU with only 4 gb of ram.  Am I right?  I've also been curious if it has to do with the fact the apu is called a quad core but 2 cores are supposedly dedicated to the gpu?
Also would upgrading to the max 8gb of ram make enough of a difference to justify the trouble of swapping out the memory module.  On this model of laptop you have to take of the keyboard and some other stuff to get to it.
If I do swap out the memory is there anything else I might want to think about upgrading while I'm under the hood?
Thanks to all
https://linustechtips.com/topic/441796-amd-a8-6410-help/
is it not working or lagging ? if u are playing nowadays games its better to get 8GB RAM
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/441796-amd-a8-6410-help/#findComment-5921393
Newer games require a powerful computer, your laptop with an APU won't cut it for that, you will run them but with poor frames per second.
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/441796-amd-a8-6410-help/#findComment-5921394
