I know you can make bootable operating systems, but can you do full OS install on USB?
I know it's dangerous (data loss, usb stick moving around losing connection whatever).
But today we have 128GB USB sticks, that are fast-ish (250MB/s|50MB/s)
I mean like full filesystem, registry, storage... the whole shabang.
Basically running a full windows system with storage without any harddrive.
Only my 128GB usb drive
https://linustechtips.com/topic/441297-full-system-on-usb-30/
windows has a feature called
Windows To Go
so yes you can and it is safe
i believe windows to go only supports USB 2.0 and 3.0 up to 32GB. so no less and no more than that.
i might be wrong tough!
https://linustechtips.com/topic/441297-full-system-on-usb-30/#findComment-5914937
It's very easy to make a Linux LiveUSB. Actually, I used to get in trouble at school for using booting Linux on the school PCs.
The biggest problem with USB sticks is that they have a limited number of write cycles and (with very few exceptions) don't support TRIM. Cheap ones die fairly quickly.
Linux expert.
https://linustechtips.com/topic/441297-full-system-on-usb-30/#findComment-5915615
