Hey I want to build a new system for a while now and i finally have the opportunity but im having problems deciding what pump/reservoir i should be using (the size, or power) here is my build
Msi 970 white and black edition OC
Lian li PC-O5S-PC O5SX Case (Mini atx)
Asus Z170-A lga 1151 motherboard
I5 6600k unlocked chip
Evga 80 plus gold 550 watt G2 fully modular
EKWB Supermacy Evo Nickel
Pump-???
Resevoir-???
Samsung 850 evo 250GB
WD black 1TB HDD
Windows 10
Corsair sp-120 Fans
Corsair Vengeance Lpx 16 gb (4X4) 2400mhz ddr4 ram
Ek Coolstream SE 240mm radiator
Plz help FAST!
https://linustechtips.com/topic/436409-water-cooling-help/
Pump should be some Laing D5 Vario variant, it's the only pump you'll ever need. Ones with aftermarket tops (like EK, Bitspower and Swiftech) are the best to go for, as they're compatible with G1/4" threads (so, pretty much every fitting available).
Reservoir doesn't really matter. Size doesn't make any difference to performance of the loop, it will just make the loop faster to fill, the bigger it is.
https://linustechtips.com/topic/436409-water-cooling-help/#findComment-5850114
