Rate Album   star_off.png star_off.png star_off.png star_off.png star_off.png  PC of Parts
Hi there all and welcome to my el-chepo build because i got bored and bar RAM i had a PC laying around in pieces,
Now Time to go into detail :-
Mobo : ASUS P5P43TD Rev 1.00
CPU : Intel Core 2 Duo (LGA775) E6320 @ 1866MHz
RAM : 2x2GB Hyperam 1333MHz
CPU Cooler : Cooler Master 212 Plus ( 92mm ( with a 120mm fan straped to it ;) ))
GPU : MSI nVidia GeForce GT 210 Fanless
PSU : FSP Group inc. 350 Watt
HDD 1 : WD 250 GB Blue
HDD 2 : Seagate 20GB (out of an old xbox 360 )
Case : Is from a family members old PC
OS : Win 7 Ultimate 64-bit
The whole build cost me £31.98 for the RAM plus a couple quid for a red and a green spray can to do the side panel because i was bored of the plain black lol , the case was an old one from a old PC of the family, PSU is what was in there with the previous system, the cooler is mine from when I upgraded to a H60 in my Personal Rig, as for the motherboard that was donated to me by a friend when his Celeron D 345 Prescott finally died 6-8weeks ago so with all these things and being bored while the parents are away i thought i'd make a s****y little system to chuck about, use in the shed, media system / torrenter because i'v undervolted the fans to 7V so it actually runs rice and quiet ! :D 3x120mm fans, i even opened up the psu and just rigged/wired it to 7v inside its self, case fan is 7v via molex re-pining, same with the CPU fan just pined at 7v but have a signal wire to the #CPU fan header so i can still read fan speed :) and there isn't any fans on the GPU so thats a win :)
Intel Core i3 530 Clarkdale @ 4.82 Ghz ! :D 64.5% O.C !
Daily @ 4.2 Ghz ;) 43.8 % O.C
Intel® Core™2 Duo E6320 Stock @ 1.86 Ghz --->> OCed to 2.97 Ghz 60 % O.C !
https://linustechtips.com/topic/43535-parts-pc/
So this was stock before i  fiddled with it
Processors Information
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Core 2 Duo E6320
Specification Intel® Core2 CPU 6320 @ 1.86GHz
Package (platform ID) Socket 775 LGA
Core Stepping B2
Technology 65 nm
Core Speed 1862.2 MHz
Multiplier x Bus Speed 7.0 x 266.0 MHz
Rated Bus speed 1064.1 MHz
Stock frequency 1866 MHz
After i had my first fiddle with it ;)
59.56 O.C ! :D  2.96Ghz :D
http://valid.canardpc.com/2883397
not finished yet still gonna see if i can squeeze a bit more out of it :P
Codename Conroe
Technology 65 nm
Core Speed @ 2968.0 MHz
Multiplier x Bus Speed 7.0 x 424.0 MHz
Rated Bus speed 1696.0 MHz
Stock frequency @ 1866 MHz
FID/VID Control yes
FID range 6.0x - 7.0x
Max VID 1.350 V
Second fiddle with it O.C 2
60% :D 2975.93 MHz (425.14 * 7)
a massive 0.2678 % /\ increase /\ over the last O.C
http://valid.canardpc.com/2883419
How ever i just can't seem to break that magical 3Ghz mark :S if anyone has any helpful tips much appreciated
Any way this is motman0591 signing off for now
https://linustechtips.com/topic/43535-parts-pc/#findComment-569047
