I am wanting to build a totally new computer. I dont really know where to start. I have a $1200 budget. I would like a dual graphics card config, a radiator liquid cooling ,some kind of i7 processor, and 16gb of RAM. Other than that I am not really sure where to go. If anyone can help in anyway, it would be great. I will be mainly using this for gaming. It will be used in a duel computer streaming config, my current computer is an X51 R2:
  • i7-4770 CPU @ 3.40GHz
  • NVIDIA GeForce GTX 760 Ti OEM
  • 16GB RAM
https://linustechtips.com/topic/434485-wanting-to-build-a-computer-need-help/
  • 16GB RAM
What currency?
Intel Core i5-4460 3.2GHz Turbo 3.5GHz | 8GB Kingston DDR3-1333 | MSI Radeon R7 370 OC to 1020mhz | EVGA Supernova NEX B1 750W | GIGABYTE GA-B85-D3H | Inwin Velocity OEM Case | 120mm broken fan
Vancouver, BC | O Canada
1. one stronger card is better than 2 slower ones
2. 8gb of ram is enough for gaming
3, you can get a liquid cooler for the cpu in that budget but not an all liquid cooled build
AMD Athlon X4 750k; Gigabyte F2A88XM-DS2; 8Gb Corsair XMS 1600 Mhz; AMD Hd5670 1Gb DDR3; Bequiet E6-600W; W7 Ultimate x64
#KILLEDMYWIFE        so miner; very doge; much value
Dell Vostro 5470: i5 4200U Nvidia GT740m 2Gb 14" 1366x768 Kingston V300 120Gb
If you don't plan on using your old computer after building the new one, I'd just reuse the 16 gb of ram.
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
US currency: http://pcpartpicker.com/p/LtjdQ7
This was hard as for me all the prices i got mixed up because i normally use the canadian website because i am canadian. ;)
Use whatever case you want, Im just obsessed with the 230T
I do plan on still using my original computer, and the currency is USD.
I will also be using the computer for editing>
Is this computer only used for editing or will it be used to game? If gaming, what sorts of titles?
This is what you asked for. Except for the dual gpu. Dual gpu is simply not reasonable given the budget. This system will handle the addition of a second gpu without problems.
CPU: Intel Xeon E3-1241 V3 3.5GHz Quad-Core Processor  ($263.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($103.99 @ Amazon)
Motherboard: Asus Z97-E ATX LGA1150 Motherboard  ($119.99 @ SuperBiiz)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory  ($77.99 @ Adorama)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($89.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($47.78 @ OutletPC)
Video Card: EVGA GeForce GTX 970 4GB ACX 2.0 Video Card  ($324.99 @ Amazon)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($54.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply  ($111.99 @ SuperBiiz)
Total: $1195.70
Generated by PCPartPicker 2015-08-23 22:05 EDT-0400
