Hi guys, so I'm looking for any suggestions or improvements that can be made to this build. The price CANNOT go any higher by more than a dollar or two. Once my friend saves up he will likely buy a GPU to add on, but for now just the APU is the best option.
http://pcpartpicker.com/user/LeviLeach/saved/M62MnQ
Also, he definitely is buying a legitimate Windows copy, so please don't suggest we just download windows 7/8, upgrade to 10 for free, etc. As he doesn't wanna do that. Thanks so much in advance!
https://linustechtips.com/topic/431891-500600-build-improvements/
While no-one should advocate pirated copies of windows it does have its good points  :D  :D  :D
DISPLAYS: LG 27UL500 IPS 4k60hz + HDR and LG 27GL650F IPS 1080p 144hz + HDR
LAPTOP: Lenovo Legion 5 CPU: AMD Ryzen 7 5800H GPU: RTX 3070 8GB RAM: 16GB 3200MHz (2x8GB DDR4) STORAGE: 4TB Crucial P3 NVMe SSD + 2TB Samsung 970 evo plus NVMe SSD DISPLAY: 1080p 165hz IPS OS: Windows 11 Pro x64
