I've recently overclocked my CPU using MSIs software (command center) and the temps were fine @ 4.4ghz but you have to enable it everytime you boot and it's a pain in the ass so I ventured onto Youtube and figured out how to successfully overclock via the bios. Currently, as of writing this message, the temps shown by AIDA64 are 40 °C  (104 °F) on the CPU and 46 °C  (115 °F) on Core 1-8, note that I only have Microsoft Edge, AIDA64, Realtek Audio Manager and Nvidia GeForce Control Panel as well as the default background programs. My case is a NZXT S340 with the 2 default fans and the radiator of the H100i mounted at the front. Through the bios I'm now at 4.3ghz with +.230 voltage. I was interested in lowering my temps because as far as I'm concerned, 45 degrees is stupid high when Vishera cpus can only stand temps up to 60 ish degrees. This is without playing any demanding games/stress testing. If it's any help as well, I am running a GTX 970 Strix so the fans from that aren't usually on as well as a EVGA SuperNova 650w PSU. Thanks for any responses.
https://linustechtips.com/topic/429437-fx-8320-h100i-temps/
If those are the temps under load, you're fine. My custom loop reaches 55C under load at 1.5v. I wouldn't worry  about it. Idle should be 30 - 40C on the high end. You could always try reapplying thermal paste. Try to get that thing to 4.6Ghz. I know you can do it without much of a volate bump (unless you were real unlucky with the silicon lottery).
blackshades on
https://linustechtips.com/topic/429437-fx-8320-h100i-temps/#findComment-5759425
Those were the temps with a minimal amount of programs open, no stress, under load it reached well into the 70s.
https://linustechtips.com/topic/429437-fx-8320-h100i-temps/#findComment-5759431
Yep those temps are very high. What's the exact voltage on your CPU? 1.38v?
I would try reapplying the thermal paste. Can you hear the pump spinning?
blackshades on
https://linustechtips.com/topic/429437-fx-8320-h100i-temps/#findComment-5759445
1.56, at 4.3ghz.
I cannot hear the pump spinning.
When I first got the H100i idle was at 12 degrees at stock speeds if that helps.
https://linustechtips.com/topic/429437-fx-8320-h100i-temps/#findComment-5759486
Vishera is only safe for 60C?!?!?! shit man that sucks.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
https://linustechtips.com/topic/429437-fx-8320-h100i-temps/#findComment-5759488
1.56, at 4.3ghz.
1.56v!? Dude that's way too high. That's basically the max and of course you're going to hit 70C. Bring it down to stock speeds AND voltages. JayzTwoCents has a basic beginner guide that should get you to 4.6Ghz with minimal voltage. Maybe around 1.42v
blackshades on
https://linustechtips.com/topic/429437-fx-8320-h100i-temps/#findComment-5759504
I had a feeling I was gonna hear that. Thanks for the help, I'll try now.
https://linustechtips.com/topic/429437-fx-8320-h100i-temps/#findComment-5759550
Thank you for your help, I appreciate it :)! Got it running at 4.6ghz @1.44v under load at 48 degrees and 28 idle.
Wow nice! 4.6Ghz is great and will boost the performance of your CPU by a fair amount. I know it did for me. Great temps as well. You're welcome!
blackshades on
https://linustechtips.com/topic/429437-fx-8320-h100i-temps/#findComment-5759724
