push pull fans
Solved by 0x1e,
hello is it better to have just 2 fans on a 2x 120mm rad or 4x 120mm fans in push - pull style
my rad is a 120 by 240mm by corsair
Always use pull, makes it easier to clean and doesn't effect cooling.
Push pull has no real effect. Maybe 1-2 cooler depending on the rad. If you have a thin rad then you may benefit from push pull but not by much.
The main reason for push pull is the have the fans spin slower for less noise.
