Hey,
I've had this PC for about 5 months and only started having the problem of my CPU fan cutting out very recently. What happens is, the fan will stop and temperatures will rise, resulting in me turning the PC off for around 20 minutes for it to cool off. After it waits the 20 or so minutes, then fan comes back on and works fine. This has only happened about 3 times now in the past 2 weeks, but I'm not sure why.
Specs:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard  ($125.98 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($97.89 @ OutletPC)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card  ($318.99 @ SuperBiiz)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($15.99 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($86.98 @ OutletPC)
Total: $1230.53
Generated by PCPartPicker 2015-08-11 17:05 EDT-0400
https://linustechtips.com/topic/428078-cpu-fan-stops-rotating/
check the bios for any fan curves or try using another fan header on your motherboard. i've had many experiences with fans not spinning at all and by just reinstalling the fan connector with the fan header on the motherboard the problem got solved
CPU:  i7 5820k  @4.0Ghz Cooler: Thermaltake Nic C5 Motherboard: MSI X99A SLI PLUS  Ram: 8 gb @2133Mhz GPU: Gigabyte GTX 970 G1 @1560  Case: Proprietary Sun Ultra 24  Storage: HyperX 120gb & 1 TB WD Green PSU: Cooler Master 550w
https://linustechtips.com/topic/428078-cpu-fan-stops-rotating/#findComment-5742180
try checking the BIOS if that doesn't work then try replace the fan
CPU - i5 4690K @ 4.5Ghz l CPU Cooler - Nepton 240m l GPU - MSI GTX970 gaming 4g 2-way SLI l SLI Bridge - MSI Gaming 2-way L Pro l Mobo - MSI Z97-G45 Gaming l RAM - 2x8GB Vengeance Pro 2133mhz DDR3 l PSU - Corsair HX750i l SSD - 2x Samsung 840 Evo 250GB in raid 0 | HDD - WD Black 2TB | Case - NZXT H440 Red/Black l OS - Windows 10 l Mouse Logitech G502 l MousePad - XTRFY NiP lightning l KeyBoard - Corsair Vengeance K70 RGB (Red) | Headset - Asus ROG Spitfire | Monitor - Asus PG279Q - VG248QE l PCPP - http://pcpartpicker.com/p/sxTpsY | Please don't buy CX PSU for a high end PC
https://linustechtips.com/topic/428078-cpu-fan-stops-rotating/#findComment-5742237
Checked the bios. I see my fan there and the speed that it was turning, but there wasn't an option to speed it up or anything. Would I replace the fan itself or the entire heatsink unit? Thanks for the reply.
https://linustechtips.com/topic/428078-cpu-fan-stops-rotating/#findComment-5742934
replacing the heatsink wont make a difference, it's the fan that is the problem, id get a bequiet or nf-f12 for it if they are in budget
https://linustechtips.com/topic/428078-cpu-fan-stops-rotating/#findComment-5743026
