Something happened when I turn on my computer my keyboard at first shows to be working but as soon as the loading is done it shuts down need help I don't want to lose any data
Please help I hdont wanna end up with removing and reinstalling windows
And if your gonna ask no I did not messbwith the bios
I also tried changing ports but nothing seems to work
https://linustechtips.com/topic/427830-help/
We need more information.
System specs? Does it POST? Can you enter the BIOS? Have you overclocked recently? New hardware installed? What have you tried to get it working? Tried only using a single stick of RAM? Do the fans spin up? Any beeps or error codes (if your board has that). ....Anything?
https://linustechtips.com/topic/427830-help/#findComment-5738829
I don't tweak around much no new hardware no such errors it works perfectly normal has usual but the only problem is with my keyboard a second its working then after boot screen its not I've tried changing ports shutting down and restarting my PC but its always the same answer
There is only a single beep as usual no errors I assure you
https://linustechtips.com/topic/427830-help/#findComment-5738866
My PC specs are a h81m-c with a g3258 and a gtx 650 synergy edition and with a delicious side of 4 gigabytes of corsair vengeance RAM with gzx7 case and a 420W gigabyte power supply oh yeah and a TB of western digital green storage
I've checked tomshardware forums and other places they say do a complete reinstallation of your windows but I don't wanna risk losing all my data please
https://linustechtips.com/topic/427830-help/#findComment-5738922
-snip-
please understand, that this forum is international and not everyone can jump
immediately to your rescue due to time-zones. we know your question is important,
but SPAMming this topic will usually turn away any helpful solutions. give it time
for other to see the topic and respond. otherwise the topic can be removed as SPAM.
https://linustechtips.com/topic/427830-help/#findComment-5739054
sounds like a dead keyboard... im not sure but I think the suppliment of power to the keyboard changes when you enter the os vs the bios... I thought it ran on a different auxilary type power when in bios.. may be wrong but try a different keyboard.
We're all dying slowly
Pentium G3258 3.2 ghz / ECS z97 pk MOBO / Intel Stock Cooler / R9 290 DD / Corsair Carbide Air 240 / 4GB mushkin stealth ram at 1600 / XFX 650W 80+ gold PSU / Kingston v300 240GB drive W/300GB seagate drive / HP x2301 / Gateway KB / Monoprice GM
https://linustechtips.com/topic/427830-help/#findComment-5739144
what keyboard is it
if applicable run to bestbuy or something get a crap keyboard and use it to update the drivers on your current one... do your other usb devices work on the ports?
https://linustechtips.com/topic/427830-help/#findComment-5739246
I would say that for the sake of spending a few quid on a cheap keyboard, it would be worth it. If you can get a PS/2 keyboard and mouse that would be even better as they definitely require no drivers or installation, anyone who likes to tinker or tweak should have a battered old PS/2 keyboard knocking around even if it is just to change a few goofy settings in a BIOS every now and again when USB seems to be failing.
Another simple diagnostic to see how bad your issue is. When the system is on and unresponsive, is the HDD light doing anything? Does the clock on screen keep time? either of these could indicate it really is just an input issue and the computer is fine. Equally, if you press the power button to switch off, does the system begin shutting down on it's own or do you have to hold the button for 5-10 seconds to force the machine off?
Is the keyboard plugged in next to another device? if so what is it? USB ports TYPICALLY work in pairs providing 5V and 500mA to each PAIR of sockets, so if you have a set of USB speakers or a USB powered external hard drive plugged in next to your keyboard, try removing them or reconnecting them somewhere else. In a typical scenario, having a keyboard and mouse plugged in together is fine but devices which require quite a bit more power do need to be somewhat spread out, either into a different pair of ports or a different controller if available.
Have you tried your input devices on a different controller? If they don't work in any of the USB2 ports, what about USB3? Is something stuck in/broken off from one of your USB ports? I have seen people accidentally break off USB socket parts leaving the 4 connectors trailing or less frequently breaking off the inside of the plug in the socket, doing so can at best short out that pair of USB ports or shut down the USB controller. At worst it can short out and cause the entire system to fail to boot.
With the symptoms you've stated, I suspect it's the driver for a power hungry USB device which is kicking in, activating the power hungry device and preventing other devices plugged in near it from functioning. If it's the 4 USB2.0 ports on your board you're using, as a rule of thumb, just use every other one unless it's for something like a printer which gets power from the mains, or if it's simply a keyboard or mouse which use not much power anyway.
One last Caveat, IF it's a K70 RGB or something which requires two USB connections just to run it (wasn't it something stupid like one for inputs and one for the lighting controller?) use a different pair of sockets for each connector. Laptops are limited in their connectivity and are pretty good at putting a lot of power into their sockets, but desktop boards have WAY more inputs, so sometimes you just need to be a little more creative with connectivity.
https://linustechtips.com/topic/427830-help/#findComment-5739400
i tried removing all usb devices and mice but that did'nt seem to work i alsokept only the keyboard and mice together and all others away but that did'nt do it either after boot screeen it (the keyoard) just shuts down and yes when i press the power button on the boot screen where i am supposed to press enter to type my password it shuts down without saying shutting down but that 's pretty usual never see that having be  a problwm
https://linustechtips.com/topic/427830-help/#findComment-5741080
maybe i was'nt that much clear last time th problem is like this when i usually turn on my PC  the asus screen appears below it at the edge of the screen it says the usual press delete to enter the uefi bios then the asus boot screen appears loading for the windows password screen to appear thats when it suddenly shuts dowbn all the way before it works just fine even in the bios all locks perfect the lighting perfect but when the screen appears of entering password it suddenly shuts down so wierd i have no idea what to do i have tried all ports available to the PC tried restarting ti but nothing came up
https://linustechtips.com/topic/427830-help/#findComment-5741156
mow another problem has shown up I tried to install windows via a flah drive but it doesn't recognise the flash drive and the setup does not start it just boots please help!
if you are still on your old windows 8 install, try system restore and go back few days, its worth a try and its quick.
https://linustechtips.com/topic/427830-help/#findComment-5741893
