Hey guys so I am looking for a new cpu cooler. I currently have a h100i that is under performing. I bought it used about 6 months ago so I wouldn't be surprised if it is dying out. I also just got the be quiet silent base 800 that has vented holes in the back of the top of the case where my radiator is mounted. I feel that the airflow there isn't that conducive to aio coolers anyways (it is in exhaust and pull). For example as I am typing without anything else running in the background, I am in the mid to high 40's Celsius on my 5820k and I peek into the mid 80's low 90's for load. With that being said I am looking to air cooling. Is that a good Idea and what air coolers are great for the money? Thanks a lot
https://linustechtips.com/topic/426841-cooling-solution/
I would think that cooler should be good for a while.  Did it ever cool well and did you consider trying a new configuration instead of replacing it?
If you are interested Id make the Rad fans intakes and also go push pull meaning 4 fans, 2 on either side all sucking air into the PC.  One thing you can check is what temp is it inside your case and how hot is the exhaust from the rad.  Also are you over clocking and what values?
https://linustechtips.com/topic/426841-cooling-solution/#findComment-5726255
I only said that its day may be done because I got it used so who knows how long it has been going for. I am overclocked to 4.0 ghz at 1.2v which is fairly tame as far as I know. I can try to see if I have some fans lying around for the push pull idea but I feel like the fans will be starved becuase there are only very small slits at the top for air to get in at.
post-234520-0-25451000-1439155981_thumb.
https://linustechtips.com/topic/426841-cooling-solution/#findComment-5726546
That was my other thought.  If you are choking the radiator then it doesn't matter if you spend $500 on a custom loop really.  The extra fans and setting it up as an intake should help a little but putting it in a place it can breath will work even better.
https://linustechtips.com/topic/426841-cooling-solution/#findComment-5726606
Best for the money: Phanteks PH-TC14P
Best overall; Noctua NH-D15 or CRYORIG R1 Ultimate
Not considering more budget centric options because an extreme edition outputs more heat, so, you need high end cooling if you wanna overclock
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/426841-cooling-solution/#findComment-5726654
From Newegg
Radiators
- Front 120/140mm
- Rear 120mm
- Top 120/140 or 240/280mm
I just noticed that.  Honestly try my suggestion from before, make it an intake and if you can fit an extra set of fans do push pull.  If you just cant seem to get good flow in there then air cooling might be the best option since that's the only slot to fit a 240/280 radiator.  You can feel if its moving a good amount of air by putting your hand under the fans/rad.
https://linustechtips.com/topic/426841-cooling-solution/#findComment-5726731
From Newegg
Radiators
- Front 120/140mm
- Rear 120mm
i'll do that thanks a lot
https://linustechtips.com/topic/426841-cooling-solution/#findComment-5726745
