Does cable extension cables reduce the power delivery from the psu? :-)
MSI Z97 Gaming 5 | I5-4690k| Dark Rock Pro 3 | ASUS RX480 |  Kingston HyperX Beast 8GB | Samsung 850 EVO 250Gb|
   Playstation Pulse Headset Corsair Air 540 | Deiog DY-200 | AOC G2460Fq
Dell Keyboard | 6x BeQuiet Silent Wings PWM 120mm
Built  Not Bought
https://linustechtips.com/topic/422369-cable-extensions/
If they're not overly long, then no. They can cause issues if they're bad quality, so don't go for really cheap ones. (Most sleeved kits are decent quality, cable wise)
Im going to get some sleeved cables from www.icemodz.eu idk how their quality is?-
Built  Not Bought
https://linustechtips.com/topic/422369-cable-extensions/#findComment-5672061
No.
Ok, thanks :)
Built  Not Bought
https://linustechtips.com/topic/422369-cable-extensions/#findComment-5672062
It's pretty good. They won't cause any issues.
Thank you :)
Built  Not Bought
https://linustechtips.com/topic/422369-cable-extensions/#findComment-5672073
