Multiple disks - power plan
Go to solution Solved by creativemagic,
Setting it to Never will keep all disks running.
Setting it to ( for example ) 10 minutes will sleep/turn off all other disks besides the OS drive. ( since it's always being used, it won't turn off.)
That being said, the option controls all Hard disks (and SSD's)
In my system I have 1 SSD for the OS and 1 HDD for stuff, and have it set to turn off after 10 minutes, the SSD stays running, but the HDD turns off.
Hi there!
I have 2 samsung ssd's and 1 hdd attached to my computer. The os is on one of the ssd's and the other 2 disks are just partitioned in disk management to be used for other stuff.
What I would like to know, will putting this setting to "Never" disable auto shutdown for all 3 disks or just for the one that os is installed on?
I would not like to have the other ssd and the hdd shutdown after a while, I would like to keep all 3 disks ON.
3884.clip_5F00_image0024_5F00_5B11E47F.j
CPU Intel Core i5 4670k 4.4Ghz Motherboard MSI Z87-GD65 Gaming RAM Kingston HyperX Beast 16GB 2400Mhz
GPU GIGABYTE GTX 780 Windforce 3X OC Case Cooler Master HAF XM Storage Samsung 850 PRO 256GB, Samsung 840 EVO 256GB, Western Digital Blue 1TB
PSU Corsair RM 750 Display(s) Philips 22" Cooling Corsair H80i Keyboard OZONE Strike Pro
Mouse GIGABYTE M7 Thor Sound Genius 5.1 Surround Sound System Operating System Microsoft Windows 10 Pro Voltage Control NZXT Sentry 3
https://linustechtips.com/topic/420980-multiple-disks-power-plan/
There's also not really anything to "turn off" or worry about with a SSD, since it has no moving parts that need rest.
"Epic Voice, Quality Content"
