Wifi fix
Go to solution Solved by STEAL7HY,
There is something called a power-line adapter. It transmits internet through the power lines in your home. I'd suggest looking into that and seeing how it compares.
Ill give it a try thanks!
What I want to do is to get a box of network cable (CAT5e) And wanting to put a wire from the living room (Where the modem is *cannot be moved!) and run it under the house to my room and Doing a TP-LINK TL-SF1008D 8-port 10/100Mbps Desktop Switch. I need enough for 3 PC's And one Xbox 360 And Xbox One
Is this a good idea or can I just keep my money and move on?
I only get 18 Down 1 Up and I think its triple that on wired!
Thanks
~Tehepic
https://linustechtips.com/topic/416927-wifi-fix/
