Hello,
1. Let me apologize for misspelling or bed English, because english is not my first language.
2. PC specs
Mobo: Abit IX48-GT3
CPU: Intel Core 2 Duo €8400 @3.0 ghz
Ram: 2x Corsair XMS3 DHX CM3X160C9DHX 1 GB and 1x Transcend JM1333KLU-1G 1 GB And now the problem.
GPU: Nvidia Geforce 9600 GT
OS: Windows 7 Ultimate SP1 x64
My first problem ( and this problem I have from the start, but that dosen't bother me much) is when I go to BIOS to check CPU temp is 103°C and it dosen't matter if pc is off all night and then I turn it on and immediately check temp or if it is on all day and I restart it and then check temp. I will add a picture.
My second problem started approximately 2 weeks ago. Problem is when I restart PC I get a error on my motherboards display. The error is C1. In User's Manual under AWARS POST Code Definition says:
C1-
Detect memory
- Auto-detection of DRAM site, type and ECC
- Auto-detection of L2 cache (socket 7 or below)
So the pc dosen't boot into windows. If I reset pc i get the same error. I have to clear CMOS with button at the back of mother board and restart pc. When it restarts and if i go to BIOS to set boot order or if I don't change anything and just pres F10 to save settings and restart I get same error, but if i press F1 to continue and i don't go to bios at all it will boot and work normal.
I tried using differnt RAM but i get the same error.
I know the PC is old because i have it for 8 or 9 years but it work very well so far and it's good enough for what i use it for so i don't want to buy new one and if someone have any advice how to fix the problem i will much appreciated it.
Again sorry for any wrong spelling.
Temp image:
http://imgur.com/g3GDTny
https://linustechtips.com/topic/416012-problems-when-restartng-pc/
