https://azerty.nl/winkelmandje/winkelmandje/?legen=1&product%5B478347%5D=1&product%5B724119%5D=1&product%5B528532%5D=1&product%5B444348%5D=1&product%5B739957%5D=1&product%5B624119%5D=1&product%5B649109%5D=1
I will buy this pc in parts and don't know what to get first. In what order should i buy them? Atm i have 44 euro, maybe i'll get 70 back in like two weeks, and over two weeks 60. So in 2 weeks i have around 170 euro's. I also have a 5 euro voucher from www.coolblue.nl which expires at 21-10-2015.
Thanks!
https://linustechtips.com/topic/414364-what-parts-first/
Just wait and save on shipping costs! It's not going to work faster if you get parts in seperately anyway :P
Case: Meatbag, humanoid - APU: Human Brain version 1.53 (stock clock) - Storage: 100TB SND (Squishy Neuron Drive) - PSU: a combined 500W of Mitochondrial cells - Optical Drives: 2 Oculi, with corrective lenses.
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5575114
just wait until you have the money for the whole PC and then buy everything.
And with an SSD this PC would be nicer ;)
i'm on a tight budget.
I still have the voucher... I want to know what to do with it. It expires in 3 months.
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5575117
So you could wait till then, clearly.
If you want to order things, just get stuff that is least likely to get price cuts. So nothing like a CPU or GPU. A Case or a PSU would be pretty stable for example, or DDR3 RAM.
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5575174
okay can you help me to get the right case? My mobo is going to be an asrock b85 anniversary: https://azerty.nl/0-5602-739957/asrock-b85-anniversary-.html
What case should i get?
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5575301
You should get an AXT case (important) that comes from a good builder with a look that you like. Typically I like cases from Phanteks the most, but I never hesitate to recommend Corsair, Fractal Design or NZXT cases either. Just pick somethign that works for your budget and looks good to you!
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5575311
Have a look at the corsair 200r case
And a 120 GB SSD would cost the same as that hard drive.
Off course if you need the 1TB space and you have not 60 euros left -> go for the hard drive (and maybe update later, but an SSD makes nearly each PC quick)
And if you want chaeper PC -> maybe look for a cheaper shop in e.g. Germany (e.g. mindfactory)(20€ shipping -> but compnents are lot cheaper)
And if you are student and need a Windows -> Windows have a 60€ student offer on their site (normally 90€)(the pro cost even more and the offer is for a pro version)
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5575348
i was wondering about the usb ports. the mobo has 4xusb 2,0 and 2x usb 3,0. Does it matter if the case doesn't have those excact ports?
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5575521
the ports are at the back so that does not matter. (each mainboard include a backplate that you put at the back of your the case (important is just the form factor, you  need an ATX case because the mobo is ATX).
That backplate is made for you mobo so the ports at the back will fit.)
What matters are the internal headers of the motherboard: if the case has a usb 3.0 at the front you need a header to plug in the USB 3.0 cable.
I will look if you board have this.
The Board has a USB 3.0 header -> so everything OK.
backplate example:
that comes in the box of the mobo.
You can then put it at the back of the case, and your mobo will then fit.
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5575532
What Clemens said is true, you'll hook up the case's USB ports with internal cables to the mobo, the mobo's own ports will always fit in the case.
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5575605
backplate example:
http://www.computerstore.nl/product/352165/category-211985/cooler-master-cm-force-500.html is this good?
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5575872
Thanks!
just hold your money and save. A new cpu is coming out soon. Also, sales are coming with promo codes online, wait till you get the best deal!
I am a ... NVIDIA FANBOY!
https://linustechtips.com/topic/414364-what-parts-first/#findComment-5576595
