Blue LED speaker suggestions?
So I've researched extensively into what kind of speakers with blue LED lighting would compliment my rig and this is the best i can find
http://www.bhphotovideo.com/bnh/controller/home?O=&sku=1042354&gclid=Cj0KEQjw_rytBRDVhZeQrbzn_q0BEiQAjnbSHEDlBcssHoybjz3a1RVFCWKHHNwcnNUjEuR4FBQ9usUaAiIN8P8HAQ&is=REG&m=Y&Q=&A=details
Does anybody have any other suggestions i might look into? I hear the bass is kinda weak on that one. Im heavy into EDM so its a must lol. Thanks!
https://linustechtips.com/topic/413392-blue-led-speaker-suggestions/
What sort of budget? And you are better off getting black or white speakers that will blend in a little, the selection of blue LED will limit your choices otherwise. You can also add LEDs later on of course, perhaps through some form of diy project or a product like this could do?
This is all assuming you must have speakers. I believe headphones will get you better quality when around this sort of price range.
Intel Celeron 2.4Ghz - 16GB DDR4 RAM - 980 ti
