Help choosing Active partition!
Solved by The Pizza Thief,
there is a tool you can use to change the mbr, let me try to remember it and ill get back to you.
have you tried changing it through cmd?
my mbr got deleted a few years ago and i fixed it using the cmd prompt on a windows disk
easybcd will sort the issue out i think, i use it all the time.
i backup with aomei autopbackupper and ive got an iso on my C drive that i boot from memory (added it to boot memory with easybcd)
its really easy to use and if i recall you can backup with it as well
Thanks for the answer, I decided to erase everything and install windows again in a single SSD, too much trouble for me.
