Well, Windows 10.
Also you haven't used the correct PC part picker link.
CPU: AMD 7800X3D Motherboard: NZXT B650E RAM: 32GB 5600 30-CL Corsair Vengeance DDR5 GPU: MSI Gaming X Trio RTX 2070 PSU: Corsair RM850i Monitor: Samsung 27" 4K thing Cooling:Noctua Chromax Black NH-D15: Case: NZXT H510 Black
https://linustechtips.com/topic/412452-will-my-build-work/#findComment-5550744
Has a 390X and a 21:9 29" freesync display.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($199.99 @ Micro Center)
CPU Cooler: be quiet! Dark Rock Pro 3 93.3 CFM Fluid Dynamic Bearing CPU Cooler ($89.90 @ Newegg)
Motherboard: Asus Z87-Pro ATX LGA1150 Motherboard ($86.98 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($45.99 @ Newegg)
Storage: Kingston HyperX Fury 120GB 2.5" Solid State Drive ($59.98 @ NCIX US)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($70.89 @ OutletPC)
Video Card: Sapphire Radeon R9 390X 8GB Tri-X Video Card ($434.98 @ Newegg)
Case: Thermaltake Core V41 ATX Mid Tower Case ($49.70 @ Newegg)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($64.99 @ NCIX US)
Monitor: LG 29UM67 60Hz 29.0" Monitor ($379.99 @ Micro Center)
Other: Windows 8 from G2A ($20.00)
Total: $1503.39
Generated by PCPartPicker 2015-07-21 21:56 EDT-0400
https://linustechtips.com/topic/412452-will-my-build-work/#findComment-5552524
Total: $1503.39
Ive seen mixed reviews about the 390x, is it actually better than the 970? I cant find any benchmarks of the 390x, just the 390.
https://linustechtips.com/topic/412452-will-my-build-work/#findComment-5552940
I recommend the 390X as it fits in your budget and that display has significantly more pixels then a standard 1080p display.
http://gpu.userbenchmark.com/Compare/AMD-R9-390X-vs-Nvidia-GTX-970/3497vs2577
https://linustechtips.com/topic/412452-will-my-build-work/#findComment-5553065
Totally go for that build he suggested.
G3258 @ 4.5 | 8GB Team Vulcan RAM | 128GB Kingston V300 SSD (I didn't know what I was doing when I bought it) | MSI H81I Motherboard | Corsair H55 with Noctua NF-P12 | EVGA SSC GTX 960 4GB | OCZ 550W Fully Modular PSU with Noctua NF-A14 | Cooler Master Elite 130 (Soon to be something cool)
https://linustechtips.com/topic/412452-will-my-build-work/#findComment-5553133
