Gothic 1 access violation error (HELP)
So I bought the Gothic trilogy today and went to play gothic 1 and got the access violation error. I've tried disabling steam overlay, I've tried running it in compatibility mode and all to no avail :(
Are there any other fixes?
Here's the screenshot
http://m.imgur.com/gallery/lk6G3Iq
https://linustechtips.com/topic/408182-gothic-1-access-violation-error-help/
Steam
I've found this on one of Steam discussion topics. Apparently the SystemPack fixes a lot of issues with the game especially for Windows 7/8. Worth a shot I guess but I would back up the game as is so you don't have to re-download it if it doesn't work.
Here is a fix to the problem:
First, install Gothic ½ — SystemPack:
http://forum.worldofplayers.de/forum/threads/1340357-Release-Gothic-%C2%BD-%C2%97-SystemPack-%28ENG-DEU%29
After that install Fullscreen border fix (even if you don't have Windows 8):
http://community.pcgamingwiki.com/files/file/4-gothic-and-gothic-ii-windows-8-fixes/
Finally go to \Gothic\system directory, open Gothic.ini and change "zStartupWindowed=0" value to "zStartupWindowed=1". Enter your screen resolution to "zVidResFullscreenX" and "zVidResFullscreenY" and change "zVidResFullscreenBPP=16" to "zVidResFullscreenBPP=32".
If your resolution is 1920x1080, it should look like this:
"zVidResFullscreenX=1920
zVidResFullscreenY=1080
; ... used resolution
zStartupWindowed=1"
After that start the game and it should work.
Just downloaded that now I'm getting another error, this time it's saying the gothic 1.08k_mod has attempted to execute a privileged intruction?? Wtf
Hmm... Have you tried running it as an Administrator?
( Right click the .exe file -> Run as Administrator OR Right click the .exe file -> Properties -> "Compatibility" tab -> Tick "Run this program as an administrator" and then Apply)
Yep tried that, no luck either :(
I'm guessing you followed the "Installation info" bit on the Gothic ½ — SystemPack website, right?
Yeah dude, I guess I'm just gonna have to get a refund, thanks for your help though!
It might be an issue with the Steam version in your case. You could always get your refund and try getting the games on GOG.
