The audio of my computer is perfect, but when I plug my headphones in front and I have not any program or any open audio, a noise come´s to the headphones and are know what is it??
ASUS VS247H-P, Keyboard - Corsair Gaming K70, Razer Mouse DeathAdder , Cpu- Intel i7 4790K (4.0 Ghz),  MSi GeForce Gtx 960 4Gb, Ram DDR3 2x4 (8Gb) Corsair Vengance Gaming Pro, MotherBoard MSI Z97 Gaming 5 , SSD Samung Evo 120 Gb ( System Operative Intalled), Hard Drive (1 TB) Western Digital (Purple), LEPA 650W Power Supply, Case NXZT H440
https://linustechtips.com/topic/39964-i-have-a-littler-problem/
describe the sound
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/39964-i-have-a-littler-problem/#findComment-516006
normally should not hear anything, but it sounds like a vacuum and when you move the mouse you listen too
https://linustechtips.com/topic/39964-i-have-a-littler-problem/#findComment-516018
Does moving the mouse to another usb port have any effect?  Specifically one on another stack on the back of the motherboard.
"Pardon my French but this is just about the most ignorant blanket statement I've ever read. And though this is the internet, I'm not even exaggerating."
https://linustechtips.com/topic/39964-i-have-a-littler-problem/#findComment-516039
not only the mouse, without touching anything  u hear it
https://linustechtips.com/topic/39964-i-have-a-littler-problem/#findComment-517993
List the specs of your computer build. Did you install a graphics or sound card recently?
Install Gentoo GNU/Linux | "You have been placed on moderator queue. This means that all content you submit will need to be approved by a moderator before it will be shown." | top LEL
Build specs: Corsair 540, i7 2600K @ 4.2Ghz, Asrock z77 extreme4, 16gb DDR3 @1866, 2 x 1TB, GTX 560 ti
Monitors: Asus VG236H, Dell U2713HM Headphones: Koss PortaPro, DT 770 80ohm, AT-AD700 | Steam profile
https://linustechtips.com/topic/39964-i-have-a-littler-problem/#findComment-518110
no , never i use the board but wen i put the sound back dont do that just in front panel
https://linustechtips.com/topic/39964-i-have-a-littler-problem/#findComment-518115
oh, you just need to get the front panel connector away from your hard drives and fans.  That'll help anyways.
https://linustechtips.com/topic/39964-i-have-a-littler-problem/#findComment-518232
