What are those dots in your shot? I'm seeing some kind of mesh material to the left of the photo - maybe that's it. Can you mount the rad on the front at all? Also, it might increase GPU temps by a small amount, but not much at all.
My guess is 5 - 8 degrees C. Though I could be completely wrong. The EVGA Hybrid cooler does an excellent job of cooling anyways, so I wouldn't be too worried.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
lol that's my Blue Yeti.  No I can't mount it in the front because of the drive cage.
i was using a aio cooled amd 290 in a silverstone sg09 with a hyper 212 evo on the cpu.
performance was pretty good considering max temp gpu overclocked 65
and my 4670k at 1.28v 4.3ghz was around 60-65 degrees
bearing in mine the sg09 has a a massive 180mm fan above it which i turned around to exhaust
the hot air
i am sure a case bigger than the sg09 would get better temps
HAF-x,  silverstone op1000, 4670k 1.28v 4.3ghz,  gigabyte g1 sniper z87,  gskill ares 1866 2x4gb,  EVGA gtx 970 FTW 1518/7800, ocz vertex 4 128gb, seagate SSHD 2Tb
