since i live in Arizona, packages get extremely hot. Like when my CPU cooler arrived, i couldn't even touch it because it was so hot. So can components like the CPU or SSD die? my 8 gigs of HyperX Fury ram is coming in tomorrow, and i dont want it to die
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
Main Rig: i7-4790K | Corsair H100i | Asus Z97 | 16GB Ripjaws | 4TB WD Black/512GB SSD | x2 R9 290x | NZXT H440 | HX1000i | 6 Noctuas   [spoiler=SILENT BUILD] Silent build: i5-4460, Be Quiet! Pure Rock, Asrock H97, 8GB HyperX, Samsung 850 Evo 500gb, MSI GTX 970, Be Quiet! Silent Base 800, EVGA Supernova GS 650w
AMD CPU's. [spoiler=] thats right m8 get 420 no scoped
https://linustechtips.com/topic/396280-pc-components-in-the-heat/
It should be fine, even if your ambient temperature is 100F. As long as your PC has proper airflow, and you have a proper cooling setup, you're fine. As an example, my video card idles at 60c (no fans on) and that's already way above 100F. (140F) I can turn the fans on and cool it down just fine, but it's designed to be able to do this, so I don't worry.
CPU and RAM can both take quite a bit of heat before anything bad happens, SSD might pose an issue However, the CPU cooler makes sense since it's a giant thermal conductor so I doubt you'd see any problems from the rest.
no thats not what i mean. someway to explain this:
So my 8 gigs of HyperX Fury Ram is coming in tomorrow, but the package that contains the ram is super hot, so it heats up the ram. Is it possible that it can die with lets say.. an SSD?
How about the PSU and GPU?
So my 8 gigs of HyperX Fury Ram is coming in tomorrow, but the package that contains the ram is super hot, because so it heats up the ram. Is it possible that it can die with lets say.. an SSD?
No.
To generate enough heat to potentially kill any component, within any packaging, it would have to be closer to 160F, if not higher. Your packages probably aren't more than 110F when they arrive.
He means while the parts inside the packages while its being shipped to his door step.
Depends on how they pack it too actually and how long its been in transport.
Main Rig
Case: NZXT H440 White | CPU: Intel Core i5-4690K @5.2GHz | CPU Cooler: Corsair H80i Hydro Series | Motherboard: MSI Z97S Krait Edition | RAM: HyperX Fury White & Black Series 16GB (4x4GB) OC to 2133MHz | Graphics Card: Zotac GeForce GTX 980 Ti ArcticStorm | SSD: Intel 730 Series 480GB & Samsung 840 256GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA 750W Supernova G2 80+ Gold | Display: BenQ XL2420G & Samsung S20D300 | Headset: Corsair 1500 | Mouse: Logitech G700S | Keyboard: Corsair Vengeance K70 Silver RED LED
 XENON Build:
Intel Xeon E3-1230 V2 @3.3GHz | Intel DZ68BC | Corsair Dominator Platinum 2x4GB 1866MHz | Kingston HyperX 3k 240GB | MSI GeForce GTX 680 | Fractal Design Define R4 Titanium Grey | Seasonic 520W 80+ Platinum Fanless
Office Build:
Case: Fractal Focus G White | CPU: i5-8600K | CPU Cooler: Cooler Master Hyper 212 Evo | Motherboard: MSI Z370-A PRO | RAM: Corsair LPX 16GB-2666 | GPU: MSI GTX 1060 6GB GAMING X | SSD: Kingston A400 240GB | HDD: Seagate Barracuda 2TB 7200rpm | PSU: EVGA BT 450W+ Bronze
Phone
iPhone XS Max 512GB Gold
Shouldn't be an issue it's better than having it below zero when you get liquid cooling components and fluids though  :P
No.
Alright thanks guys :)
