I looked all over and couldn't find any' date=' might just have to go with 140mm fans with 120mm spacing and throw green leds on them. [/quote']
Yeah it's quite frustrating, I think I'll just get 120mm green LED SilverStone Airpenetrators, at least I won't sacrifice performance with those excellent fans.
Thanks for the reply though.
https://linustechtips.com/topic/3956-need-help-with-fans/#findComment-48645
I looked all over and couldn't find any' date=' might just have to go with 140mm fans with 120mm spacing and throw green leds on them. [/quote'] Yeah it's quite frustrating, I think I'll just get 120mm green LED SilverStone Airpenetrators, at least I won't sacrifice performance with those excellent fans. Thanks for the reply though.
I looked for like 45 minutes because I was sure there had to be SOMETHING out there, but I couldn't find jack.
https://linustechtips.com/topic/3956-need-help-with-fans/#findComment-48654
those will work fine
https://linustechtips.com/topic/3956-need-help-with-fans/#findComment-49716
You may want to take a look at nocuta's older generation NF-P14 FLX of 140mm fan which was more like an enlarged version of a 120mm, they don't have LEDs but they are an alternative:
http://www.noctua.at/main.php?show=n...ounting&lng=en
https://linustechtips.com/topic/3956-need-help-with-fans/#findComment-49759
You may want to take a look at nocuta's older generation NF-P14 FLX of 140mm fan which was more like an enlarged version of a 120mm' date=' they don't have LEDs but they are an alternative: http://www.noctua.at/main.php?show=n...ounting&lng=en
Yes I'm aware of those, I was looking for similar fans but with green LED lighting .
https://linustechtips.com/topic/3956-need-help-with-fans/#findComment-49769
