what dose the the Micro ATX mean and will this work with my setup of do i need the regular ATX board.
by build (so you can tell me if i need the Micro board)
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($319.00 @ CPL Online)
Motherboard: Gigabyte GA-Z97MX-Gaming 5 Micro ATX LGA1150 Motherboard  ($209.00 @ CPL Online)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($509.00 @ Centre Com)
Case: NZXT Phantom 530 (White) ATX Full Tower Case  ($169.00 @ PLE Computers)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($95.00 @ Scorptec)
Case Fan: BitFenix Spectre 43.5 CFM 120mm  Fan  ($9.00 @ CPL Online)
Total: $1548.00
Generated by PCPartPicker 2015-06-28 12:14 AEST+1000
can you please tell me if i need the:
OR
https://linustechtips.com/topic/395460-mother-boards-help/
I'd get a full ATX board with that case. You'll get so much more room and expansion with a Full ATX board.
I recommend getting motherboards from MSI and Gigabyte.
PC: AMD Ryzen 5 1600 @ 3.8GHz | EVGA RTX 2060 SUPER | MSI B350 Gaming Pro Carbon | G.Skill Ripjaws V 16GB @ 3200MHz C14 | EVGA G3 650W
Laptop: 2023 Macbook Pro 16" - M2 Max | 64GB RAM | 1TB SSD
https://linustechtips.com/topic/395460-mother-boards-help/#findComment-5335345
Micro ATX is a physically smaller board. It will still work with your system.
Micro ATX boards can look a little dopey inside of full tower cases though.
do you know of any place that i could get this board
https://au.pcpartpicker.com/part/gigabyte-motherboard-gaz97xgaming5
in australia?
https://linustechtips.com/topic/395460-mother-boards-help/#findComment-5335404
https://au.pcpartpic...d-gaz97xgaming5
in australia?
I would get this as its cheaper and better.
http://au.pcpartpicker.com/part/msi-motherboard-z97g45gaming
https://linustechtips.com/topic/395460-mother-boards-help/#findComment-5335437
