I got my Shield Tablet for Christmas so I haven't had it but six months. It has happened for a while but more recently it has started happening even more. I will be doing normal things on the tablet when it will freeze and make a very loud buzzing sound and I will have to restart it. Is there a way I can return it and get a new one?
https://linustechtips.com/topic/389951-problems-with-my-shield-tablet/
Claim the warranty?
My article on subscription based services and why they are the way forward http://linustechtips.com/main/topic/382625-what-the-future-holds/
More specific?
Well if your parents bought it for you or you bought it, it should have a factory warranty or something, should be like a piece of paper or something so if something was to happen to it they would replace it.
http://shield.nvidia.com/support/nvidia-android-tv/faq/1
try tech support see what they can do.
If your parents or you bought it from like bestbuy my advice would be find the receipt and try to return it there.
