So I have the Enthoo ITX case and the airflow configuration is rather difficult due to the size of the heatsink I have on it (Xigmatek Dark Knight Nighthawk). Due to the motherboard layout it only fit with airflow going vertically. Graphics card is of course drawing air from below it near the power supply shroud. I have a 120mm rear exhaust and the stock 200mm intake. I have any number of extra fans (old stock fans from my H440, some corsair AF120s, etc.) And am wondering if you have some suggestions.
Pushing air top to bottom with the CPU cooler? Or pulling it bottom to top? Top exhaust? Or intake? Your thoughts are appreciated.
Cinders: - i7 4790K (4.5GHz) - Gigabyte Z97X-SOC - 16GB Klevv DDR3 1600MHz - EVGA GTX 980Ti ACX2.0+ (1548MHz Boost) - EVGA Supernova 850GS - NZXT H440 Orange/Black (Modified) -
Unnamed System: i5 4690K (4.2GHz) - MSI Z97I-AC - 8GB G.Skill DDR3 2400MHz - EVGA GTX 950 SSC - Raidmax Thunder V2 535W - Phanteks Enthoo Evolv ITX
https://linustechtips.com/topic/389338-enthoo-itx-airflow/
*bump*
https://linustechtips.com/topic/389338-enthoo-itx-airflow/#findComment-5259493
