Re-format a usb drive
By
Mr.Tech.Qc
in Storage Devices
in Storage Devices
Solved by rustikles,
http://www.supertalent.com/datasheets/Resetting%20USB%20drive%20using%20Windows%20Diskpart-V1.pdf
(Assuming you're on windows) Part of this tutorial on using Diskpart includes cleaning the partitions. You might have to do the complete process twice, but it'll display the full size afterwards.
voltigeurramon ·
Posted in Troubleshooting1 -
1
Vibora ·
Posted in New Builds and Planning5 -
5
3
Doctah ·
Posted in Peripherals3 -
8
