Hello.
Sorry if my english is not good. I speak spanish.
How many Watts I need for this build?
FX6300 3.5 Ghz Six cores
2 RAM memories.
WD blue 500 GB
Blue leds (12v)
2 fans (With leds too) and the CPU fan
Gigabyte GA-78LMT-S2
Led thermometer on.
3 adittional USB  ports
1 optical drive.
R9 280x
I'm asking this because I tried some Watts calculators and each calculator gives me a different result.
Thanks.
https://linustechtips.com/topic/388156-how-many-watts-do-i-need/
Hello.
2 RAM memories.
WD blue 500 GB
Blue leds (12v)
Led thermometer on.
1 optical drive.
Thanks.
any graphics card?
https://linustechtips.com/topic/388156-how-many-watts-do-i-need/#findComment-5239284
Oh. Sorry... R9 280x
I'd just get a EVGA 600B and call it a day. It would be enough and you should be able to find them for decent deals.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/388156-how-many-watts-do-i-need/#findComment-5239381
500-600W
My Rig:  CPU: Core i7 4790K @4.8ghz  Motherboard: Asus Maximus Vii Hero  Ram: 4x4GB Corsair Vengeance Pro 2400mhz (Red)  Cooling: Corsair H105, 2x Corsair SP120 High Preformance Editions, Corsair AF 140 Quiet Edition  PSU: Corsair RM 850  GPU: EVGA GTX 980 SC ACX 2.0  Storage: Samsung 840 EVO 120GB, WD Blue 1TB  Case Corsair 760t (Black)  Keyboard: Razer Blackwidow Chroma  Mouse: Razer Deathadder Chroma  Headset: ATH-M50X Mic: Blue Yeti Blackout
https://linustechtips.com/topic/388156-how-many-watts-do-i-need/#findComment-5239391
around 600w should be good
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/388156-how-many-watts-do-i-need/#findComment-5239442
A PSU in the 500 watt - 600 watt will be enough. Just make sure it's from a reputable brand such as Corsair, EVGA, Seasonic, XFX etc and that it's at least 80+ Bronze rated.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/388156-how-many-watts-do-i-need/#findComment-5239445
1.21 Jigawatts!!!
Joking aside, a 600-650w 80+ gold will be good as long as you don't plan to X-fire, at which point you'd want a 750w. Just make sure you get one from a reputable brand.
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/388156-how-many-watts-do-i-need/#findComment-5239477
For 5 bucks more then a 600B you can get a 750B2, which is worth more then the $5 increase for quality alone, since it's based off a much higher quality Super Flower platform then the HEC-made 600B. On top of that you get 150 watts more, and it's semi-modular. No reason to buy a 600B at this point.
http://pcpartpicker.com/part/evga-power-supply-100b10600kr
http://pcpartpicker.com/part/evga-power-supply-110b20750vr
"Rawr XD"
https://linustechtips.com/topic/388156-how-many-watts-do-i-need/#findComment-5244372
Forgot that this deal is still a thing. :)
https://linustechtips.com/topic/388156-how-many-watts-do-i-need/#findComment-5244502
