Thanks for using pcpartpicker , everything looks good other than the 1000w PSU , you will only really need 650 even with the r9 probably.
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
looks good just grab a 980ti
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
that aio cooler has quite a few of shipping issues. Good job at the case pick welcome to the enthoo family.
1000w is a little bit too much for this build maybe go with lower w but better efficiency.
gpu you should consider 980 or 980ti also tho, just saying.
CPU:  i7 4770k @ overclocked to 4.4ghz             GPU: Intel HD4600        SSD: Kingston V300 120GB (OS)                   Cooler:  Corsair H100i GTX
Case: Phanteks Enthoo Evolve (Black)                RAM: 2x4gb Corsair Dominator Platinium 2133mhz  HDD: 1TB Seagate                                            Mouse: Logitech G502
OS:     Windows 10                                                      PSU: Corsair RM850i 80+ Gold                                          Motherboard:  AsusZ97 Pro Gamer              Keyboard: Vortex Pok3r 3
you forgot to put the m2 ssd
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor ($339.99 @ Newegg)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($99.98 @ B&H)
CPU Cooler: RAIJINTEK TRITON RED 100.5 CFM Sleeve Bearing Liquid CPU Cooler ($99.99)
Motherboard: MSI Z97-GAMING 7 ATX LGA1150 Motherboard ($169.99 @ SuperBiiz)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR3-1600 Memory ($99.99 @ Newegg)
Storage: Samsung 850 EVO 500GB M.2-2280 Solid State Drive ($195.98 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ SuperBiiz)
Case: Phanteks Enthoo Luxe ATX Full Tower Case ($137.99 @ NCIX US)
Power Supply: EVGA 1000W 80+ Gold Certified Fully-Modular ATX Power Supply ($149.99 @ SuperBiiz)
Monitor: Acer XG270HU 144Hz 27.0" Monitor ($450.98 @ Newegg)
Keyboard: Corsair K70 RGB Wired Gaming Keyboard ($152.69 @ NCIX US)
Total: $1954.56
Generated by PCPartPicker 2015-06-15 21:39 EDT-0400
