So guys if you did own a hp tower or pc whatever the case maybe,please post your problems with it,there is no limit to how much you can post because i just wanna see how bad hp can get into pc development.
so ill probably start mine first
1.my laptop was a envy 14 but surprisingly it died 2 months later after use first was crashes then died after it got fixed the battery was not functioning and 2 weeks later the hard rive failed and it broke for real
2.my first printer was really bad after 2 months of use it just failed.
3 my current desktop is probably the most weirdest thing of all time its a pavilion desktop(forgot about the name),at first the onboard lan did not function then i had to get a wireless adapter, but i wanted to get a reliable connection since apparently all the marketing BS people at tech shops that they tell me in my place btw is horrible i had to buy a belkin wireless adapter,but i still got cut offs no matter the distance unless it was really close so i tried to hardwire it but after finding out it did not work i was wondering why can't i connect so after weeks of rage,i decided to try and isolate the problem so after moving one of my Apple Airport time capsule (cuz i have a macbook,tired of hp failures) and plugging it in, i found out that the motherboards own ethernet jack is either broken or it is just there bcuz for aesthetic purposes.
so whats yours hope you guys can let off all the hate you have on hp
https://linustechtips.com/topic/386000-hp-problemsflaws-post-your-problems-here/
