The Xeon is another option if you don't plan on overclocking. It has hyper threading so it will perform similar to an i7.
If you want to overclock then you can switch back to the i5 4690K as it will handle the occasional bit of rendering.
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($241.95 @ SuperBiiz)
Motherboard: Gigabyte GA-Z97X-Gaming 5 ATX LGA1150 Motherboard  ($95.99 @ SuperBiiz)
Storage: Crucial BX100 250GB 2.5" Solid State Drive  ($89.99 @ SuperBiiz)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card  ($329.99 @ SuperBiiz)
Case: NZXT Source 530 ATX Full Tower Case  ($89.99 @ Amazon)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($18.89 @ OutletPC)
Operating System: Microsoft Windows 8.1 OEM (64-bit)  ($87.98 @ OutletPC)
Monitor: BenQ GL2460HM 60Hz 24.0" Monitor  ($149.99 @ Amazon)
Keyboard: Logitech G710 Wired Gaming Keyboard  ($84.99 @ Amazon)
Headphones: Thermaltake SHOCK Headset  ($55.95 @ Amazon)
Total: $1507.65
Generated by PCPartPicker 2015-06-11 16:39 EDT-0400
https://linustechtips.com/topic/384839-need-help-balancing-list/#findComment-5197077
That 970 is the mini-itx version  B)
Damnit...
@+Recover
Yea, as said above.. you can trim stuff off here and there easily enough.
If not overclocking, the Xeon is the way to go, if overclocking the i5 is plenty capable.. I know people that use much worse systems for rendering while doing a degree in media production. Same goes for the ram.
I would suggest possibly a better monitor but thats totally user preference. A decent IPS goes a long way BUT most of the cheaper ones will suffer from motion blur in faster games. Better in pretty much every other situation though.
All just food for thought.
Ohh and unless you burn or consume medi from disks still (I know VERY FEW people who do) drop the drive and think about a Fractal Design Define S.. Bit cheaper, similar style. But no 5.25" drive bays
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
https://linustechtips.com/topic/384839-need-help-balancing-list/#findComment-5200989
