So my friend changed his motherboard of his old predator G5(i7-2700k) to the i7-5280k with a MSI x99s gaming 7. And after changing to the new system windows will not boot to install drivers. But it does POST
SATA mode has been changed to ACHI
we do not have a windows disk( although we can get one).
and most online solutions have not yeided anything.
Current specs
i7-5820k
MSI x99s gaming 7
MSI 980 gaming
16gb gskill ram
Win7 HP 64bit
MOTHERBOARD: MSI Z87-G45 CPU: I5-4670 GPU: MSI GTX 770 4GB RAM: 16GB ADATA PC3 1333MHz(got them free) PSU: SeaSonic MK2 620w CASE: Sharkoon Tauron OS: Win 10 64 bit Keyboard: Steelseries Shift Mouse: G502
https://linustechtips.com/topic/383333-troubles-with-changing-platforms/
Oh god, i had the same prob whit my predator.
Eventually i ended up buying a new SSD, because there ssd was programmed to only work with there OEM motherboard.
EDIT: What datastorage he use?
Intel i7 6700k - MSI Z17A0 Gaming M5 - 4 x 8Gb Kingston HyperX 2666Mhz - MSI GTX 970 - Samsung Pro 128Gb - WD 3Tb - 750 Watt MS-TECH
Eventually i ended up buying a new SSD, because the ssd was programmed to only work with there OEM motherboard.
He uses a 2TB WD red that he bought because the original drive that came with the Predator failed
